Hi guys
I'm rebuilding a set of twin Hitachi / SU carbs at the moment and am after a couple of bits if anyone has spares
I gave a mint set of these away a while ago haha - gutted
The parts I'm looking for atm are:
The screw assembly that attaches the arm to the fuel nozzle at the bottom of the carb - there is a little machined spacer in there (part 32) that I'm missing and the original screw and washers would be nice too
There's also a fuel return bar that connects to both carbs and is bolted to one of the main mouting studs on each carb. It's made of about 10mm tube (circled), and the standard fuel line that bolts to the intake manifold studs (circled)
I'd also be keen on a standard air filter box if anyone's got one lying around!
Thanks
Shannon
Hitachi / SU Carb parts wanted
- R30 Guru
- aka: Jordy
Re: Hitachi / SU Carb parts wanted
I have a set of these and all that's missing from them as far as Im aware is the fuel bowls and floats.
So if they are of any use to you, you'll have to wait till the end of the holidays till I can get back into the workshop at tech to get them that's all
Projects Under Development
83 HR30 GT L31ETT
82 HR30 GT VH45DET
67 A30 GLORIA 4DR SEDAN-Resto
http://www.jurassicautomotive.com/" onclick="window.open(this.href);return false;
http://www.facebook.com/JurassicAutomotive
- pl510
- aka: Shannon
Yeah mate that would be cool - not in any inrush - thanks!
Are you sure that is a "fuel return bar" in the picture it appears to connect to the fuel line, but I think it is connected to the "Vacuum" side of things. Sorry I can't help any more than that, I am missing some of the same parts.
- pl510
- aka: Shannon
Could well be actually
