a12 sluggish below ~2000rpm
beaver
Datsun Nutter
Re: a12 sluggish below ~2000rpm
Post by beaver »
i threw a carb kit at it so yes, new jets. 99% sure they are all in the right place.
hand over carb trick? do explain
trans doesnt sound/feel like its slipping. revs dont build with no extra speed or anything
Remove air cleaner, hold about 2500 rpm on it, block air intake with hand remove before engine dies, repeat. Sucks muck through jets. Jets can be accessed with carb in place, just in case you are unsure. Check they are tight. Sounds strange idle is ok, but not low speed.
2 doors
Post by 2 doors »
forgot this was an auto, but that shouldnt make much differance, keep us posted
