i got them off my workmate and i think he said that the guy that he got them off had them in a commodoreBartman wrote:Do you know what those seats are out of?
I have one of those non meshheads in my 1200.
Jordans 120y
ginga-dato
- aka: Jordan
Re: Jordans 120y
Re: Jordans 120y
I've got exactly the some ones and mine came out of a Lancer GSR, the old CC shape
ginga-dato
- aka: Jordan
Re: Jordans 120y
Stolen at around 1.45 am this morning
Re: Jordans 120y
mate, hope you get this back, shame your neighbour didnt take the time to investigate further, or at least ring the police.
ginga-dato
- aka: Jordan
Re: Jordans 120y
datsun has been found. they took the rims, head unit, speakers, gear knob and smashed the boot lock in. thank fuck they didnt take the engine. was found jacked up with just 1 spare wheel on but the bastards took my wheel nuts. they put scrunched up news paper in the front as if they were going to burn it
ginga-dato
- aka: Jordan
Re: Jordans 120y
hey guys. iv got my eyes on a set of rims that mag and tyre direct are selling thru trademe. JBW minis. they have them in 15x7 0 offset ( which is the same as wat the konig rewinds were) or 15x8 -8 offset. im thinking of just going with the 15x7's since it worked well with the konig's. im just wondering if anyone has heard anything bad about them or just your personal opinions
- brocky41
- aka: Brocky
Re: Jordans 120y
Those 8's will sit 8mm further out (offset) plus another 12.5mm (1/2 inch of the extra 1 inch widness) which means 20mm further out in total - so you could fit those to the rear - might need a small amount of massage work.
Fronts id stick with what you had as they filled the guards nicely - see if they will split two sets for stagger fitment
My 2c worth - glad you got it back though dude.
Re: Jordans 120y
I think you should run 13 by 8s!
ginga-dato
- aka: Jordan
Re: Jordans 120y
The rust repairs have finally begun. It will be a long, slow battle but all good things take time. Ended up taking my drivers door into work since it was a quiet week. Replaced both bottom corners, inner and outer layers. Came out pretty good being my first time cutting out rust and welding in patches. A lot of thanks to the panel beater, ex-full time rust cutter, at work that was helping me out. Also re-shaped the hole for my lock to fit in a solex one since the thieves busted the original
ginga-dato
- aka: Jordan
Re: Jordans 120y
got myself an alloy radiator made up as my old radiator was ruined and practically fell apart as soon as i took it out. its pretty much the same size as the original one but with a slightly thicker core and a little bit longer. was able to use an electric fan from work that was just lying around waiting to be thrown out. it just had a small crack which was an easy fix
