dan1200sss ca18det datsun 510
z18et1200coupe
- aka: The shed
Re: VG and SR killer 510
Let me know if you to sell a XR4 center cap haha
1976 NA Lancer
1979 Starlet Bugeye
1974 ke25 coupe
1972 1200 coupe z18et
1979 Starlet Bugeye
1974 ke25 coupe
dan1200sss
My custom super low adjusties from MRP up north just arrived, he had to have shorter than normal inserts ordered in for them. They are body adjustable to so can lift it up and down without touching the spring tension if need be.
- brocky41
- aka: Brocky
Im guessing these are for the front - how do they mount on the bottom - or are you changing to s13 brakes and hubs
wooooo.... Very interested in how these turn out.
dan1200sss
Cut the 280zx strut off right at the bottom leaving 10-15mm of tube and slide the body adjustable part over and have it tig welded on. I'll get new brembo discs to replace the old ones on there and prob look at some new wheel bearings. Also im thinking about getting Hilux front calipers as apparently they bolt up to factory 280zx mounts I was told ?
I got some hilux calipers if you want them.
dan1200sss
I'll be keen to mock up with one atleast and see what they fit like
datsunboy
- aka: Dan
They look awesome.... cost?
dan1200sss
$680 for the front pair including camber plates and spanners. So very very well priced for brand new good quality designed & made in NZ adjusties.
- Kitch
They are a very sweet looking setup, and that is extremely well priced.
My Coil over kit, camber plates & Monroe inserts cost me about $1K
Wonder if you could get this kind of setup into a 1200 with some bottom strut legs fitted somehow....
