same as title states. was going to put them on the coupe but they don't fit, and would need mods to make them fit, ie they are too tight against the floor pan, probably off a sunny.
asking $75
0273330715
A series extractors
Re: A series extractors
I would guess yes, but welcome the opinion of others on here who have a more up to date knowledge of cylinder head proportions
All a series headers have the same port configuration.
thanks bart, I thought so but didn't want to put anyone wrong.
- Tony_Whenua
Is this still available warrick? i could be keen if they are...hoping they'll fit the ute an all
They are still available, they may fit your ute as its running a different cross member and engine mounts than the 1200, but I could not guarantee,
- Tony_Whenua
Im currently planning on putting my worked sedan engine in the ute so will have a sedan cross-member. So in that case im guessing that it aint going to fit.
yeah, you would be correct in thinking that, sounds like a pretty cool set up though, we going to see some pics?Tony_Whenua wrote:Im currently planning on putting my worked sedan engine in the ute so will have a sedan cross-member. So in that case im guessing that it aint going to fit.
can you add heat near collector and bend away from floor??
