A series extractors
Sell stuff
2 doors
A series extractors
Post by 2 doors »
same as title states. was going to put them on the coupe but they don't fit, and would need mods to make them fit, ie they are too tight against the floor pan, probably off a sunny.
asking $75
0273330715
damz721
aka: Damian
Re: A series extractors
Post by damz721 »
Will they fit a a15 engine?
- 77 B210 S/W
2 doors
Post by 2 doors »
I would guess yes, but welcome the opinion of others on here who have a more up to date knowledge of cylinder head proportions
All a series headers have the same port configuration.
2 doors
Post by 2 doors »
thanks bart, I thought so but didn't want to put anyone wrong.
Tony_Whenua
Post by Tony_Whenua »
Is this still available warrick? i could be keen if they are...hoping they'll fit the ute an all
2 doors
Post by 2 doors »
They are still available, they may fit your ute as its running a different cross member and engine mounts than the 1200, but I could not guarantee,
Tony_Whenua
Im currently planning on putting my worked sedan engine in the ute so will have a sedan cross-member. So in that case im guessing that it aint going to fit.
2 doors
Post by 2 doors »
Tony_Whenua wrote:Im currently planning on putting my worked sedan engine in the ute so will have a sedan cross-member. So in that case im guessing that it aint going to fit.
yeah, you would be correct in thinking that, sounds like a pretty cool set up though, we going to see some pics?
grant76
Post by grant76 »
can you add heat near collector and bend away from floor??
