Done some more wiring & have done the sound deadening for the boot area.
Thanks to Nick_M I have some water cut profiles done for my ECU & radiator fan
mounts.
I just spent an hour cleaning up & drilling the radiator mount plates, and they
worked sweet! pretty stoked with how my design turned out. I have had to go pusher
fan due to lack of space for fan due to the crank sensor setup etc. she is tight but
enough clearance I believe
Water cut profiles (1 showing fan mount tabs fitted):
Mounted to the 10" Pusher fan & pre-fitted up
All fitted up!
