wtd. r200 conversion parts for a 510
oldskooldat
Regular
aka: ollie
Post by oldskooldat »
im looking at buying a 510 with an overpowered engine with a standard diff. i wont buy it unless i can upgrade the diff.
does anyone happen to have an r200 lsd diff and parts needed for a 510 for sale
can someone tell me the rough cost of the conversion.
cheers
Re: wtd. r200 conversion parts for a 510
Modified axles run into about 300.(If you can find someone to do them for you) I'd say $80-100 for HR30/910/etc outer companion flanges.
I don't know what you'd expect to pay for r30/s12/910 outer CV's. They may even be available new. (at a cost)
Then you'd need to find a longnose R200. (Others might have an idea what market value for those is)
And a shortnose LSD and inputs. (Either VLSD, or CLSD) VLSD's can be picked up pretty cheap.
It would have to run into around the $600 mark all told?
85_Z31
Datsun Master
Post by 85_Z31 »
It also requires mods to the cross member to fit the R200 in place.
torqued
aka: Adam
Post by torqued »
Diff Bracket
dan1200sss
Datsun Driver
Post by dan1200sss »
Budget minimum $1k all up I'd say TBH
pl510
Datsun Driver
aka: Shannon
Post by pl510 »
Agree
As the boys said,
Modified axles
Longnose R200
Shortnose LSD and inputs.
Moustache bar and mods to crossmember
Plus possible driveshaft mod depending on flange dimensions of R200
Fly up and have a look at it.
oldskooldat
Regular
aka: ollie
Ill b happy enough with paying a 1000. Who's got a setup they would sell
I have some replica outer companion flanges.
I say replica, as they were the standard UJ ones. The square end was machined off, then a locating spigot was turned on. Then copies of the R30/etc flange were machined up, and they were welded together. How strong are they? Tbh, I don't know. They look pretty strong though.
Rusty
Datsun Nutter
aka: Ryan
Post by Rusty »
oldskooldat wrote:im looking at buying a 510 with an overpowered engine with a standard diff. i wont buy it unless i can upgrade the diff.
cheers
I have a rear subframe less diff from s14
only the inner CV's are of any use.
Are they 3x2, or 5x1.
