F/S New Driveshaft Loop kit
Sell stuff
Datto_610
aka: Greg
Re: F/S New Driveshaft Loop kit
Post by Datto_610 »
All sorted Craig, it will be heading my way very soon :D
85_Z31
Datsun Master
Post by 85_Z31 »
gingofthesouth wrote:
beaver wrote:Just bend one up out of some 50x5mm plate/bar....will take all of 30mins.
hrspwr's driveshaft hoops are inexpensive, complete and powder coated.
Yes, if You had the tools you could bend one up, but most of us don't. So these ones are worth the small amount of money.
yes and no
I did mine with a bench vice and a hammer, and it came out mint. It depends how stingy you are.
No welding,meets all cert Requirements. All you do is make a template with some stiff wire and get bending.
It was a bit of a pain in the ass to do , but hey it was free.
gingofthesouth
Site Admin
aka: Ging
Post by gingofthesouth »
85_Z31 wrote: yes and no
I guess, if you had the plate already, the nuts and bolts already, a bench to have a vice on, a bench vice, a decent drill and a spare chunk of time it was "free".
Me, I have no bench in my garage (I don't own the house I live in), so no vice, no metal bar as I have no engineering tools in my shit garage.
I value my time, so my time is neither free nor are the tools required to make it. So, the bit where I said:
gingofthesouth wrote:Yes, if you had the tools you could bend one up, but most of us don't. So these ones are worth the small amount of money.
stands.
hrspwrs hoops look nice, comes with all the nuts and bolts and is powder coated, meets NZ standards and costs less than half an hour of my contracting rate.
If I was still in Nelson, well that would be another story.
Kitch
Post by Kitch »
That home made job looks pretty good James.
Thanks Craig for the offer, but knew someone on here would have a use for it.
Do you guys know if the hoop must be bolted two piece?
I was thinking of using a 50mm band of 5" steam pipe pressed to elongate it to shape to inside of tunnel, and slid over the drive shaft would do the trick.
would then just have a 50x5 wing tab welded to each side and bolted through floor with 2x M10 bolts each side.
any comments?
85_Z31
Datsun Master
Post by 85_Z31 »
single or two piece is ok as long as its 50x5 minimum , no more than 150mm from the UJ and supported by 4x M10 High Tensile bolts with load spreading washers on the inside of the sheet metal.
Worth talking to your cert man, do whatever he says. I showed Wayne Martin a sketch of mine before it got built and he said it was good to go.
Kitch
Post by Kitch »
cheers James, all sounds common sense.
Will design something up and get it sorted
PS; Greg, your hoop posted this morning
Datto_610
aka: Greg
Post by Datto_610 »
Thanks!
