billet cnc RCA bump steer spacers for everything datsun
Sell stuff
volodkovich
Regular
Re: billet cnc RCA roll centre adjusters for 1200s
Post by volodkovich »
I'm keen for a set of 310 RCA's too.
skdmrx
Post by skdmrx »
28mm 510 310 910 etc etc RCA's are hot off the mill.I'm sure they'll fit heaps of other stuff too,80mm hole centres/40mm spigot.Fire me a PM if your keen $170 including Hi tensile metric fine bolts.
I've still got a couple of pairs of 1200/120y ones floating around too.
Datto_610
aka: Greg
Re: billet cnc RCA bump steer spacers for everything datsun
Post by Datto_610 »
The spigot on my 180b steering arm is smaller than the spigot on my 910 strut haven't measured them properly but I'm sure a locator ring would work ok. So keen on a pair but so poor at the moment!
skdmrx
Post by skdmrx »
^^ PM sent
woodies72coupe
Post by woodies72coupe »
I could be keen on a pair too for my 310 struts.
Question is: How much do you need to lower a car before these become important?
85_Z31
Datsun Master
Post by 85_Z31 »
Usually once your front suspension arms get close to parallel to the ground you can notice a bit of bump steer.
My own Z was that exact situation and RCA bump spacers made it drive sooooooooo much better, night and day diffierence stuff.
Johns doing a cracking good deal ( and excellent job ) on these, snap them up guys !
torqued
aka: Adam
Post by torqued »
Datto_610 wrote:The spigot on my 180b steering arm is smaller than the spigot on my 910 strut haven't measured them properly but I'm sure a locator ring would work ok. So keen on a pair but so poor at the moment!
Work fine on my car,
910 Struts 510 lower arms.
That locator ring should have come with your struts
joelbrown
aka: Joel
Post by joelbrown »
85_Z31 wrote:Usually once your front suspension arms get close to parallel to the ground you can notice a bit of bump steer.
:agree:
The ute feels soo much better now
1990 1200 ute
skdmrx
Post by skdmrx »
Glad they helped out Joel.You or Adam got any pics post install?
torqued
aka: Adam
Post by torqued »
Not the best pic but I took this earlier
