billet cnc RCA bump steer spacers for everything datsun
volodkovich
- Regular
Re: billet cnc RCA roll centre adjusters for 1200s
I'm keen for a set of 310 RCA's too.
28mm 510 310 910 etc etc RCA's are hot off the mill.I'm sure they'll fit heaps of other stuff too,80mm hole centres/40mm spigot.Fire me a PM if your keen $170 including Hi tensile metric fine bolts.
I've still got a couple of pairs of 1200/120y ones floating around too.
- Datto_610
- aka: Greg
Re: billet cnc RCA bump steer spacers for everything datsun
The spigot on my 180b steering arm is smaller than the spigot on my 910 strut haven't measured them properly but I'm sure a locator ring would work ok. So keen on a pair but so poor at the moment!
^^ PM sent
- woodies72coupe
I could be keen on a pair too for my 310 struts.
Question is: How much do you need to lower a car before these become important?
Usually once your front suspension arms get close to parallel to the ground you can notice a bit of bump steer.
My own Z was that exact situation and RCA bump spacers made it drive sooooooooo much better, night and day diffierence stuff.
Johns doing a cracking good deal ( and excellent job ) on these, snap them up guys !
Work fine on my car,Datto_610 wrote:The spigot on my 180b steering arm is smaller than the spigot on my 910 strut haven't measured them properly but I'm sure a locator ring would work ok. So keen on a pair but so poor at the moment!
910 Struts 510 lower arms.
That locator ring should have come with your struts
- joelbrown
- aka: Joel
85_Z31 wrote:Usually once your front suspension arms get close to parallel to the ground you can notice a bit of bump steer.
The ute feels soo much better now
1990 1200 ute
Glad they helped out Joel.You or Adam got any pics post install?
Not the best pic but I took this earlier
