Datto_610 - Cool, I'll PM you about borrowing to check fit. Looks like they are pretty hard to find now, so I'll want to make sure it will work before ordering.
Brocky, did the guys at BNT have any luck? May still be good to know if the RX masters are a good option given the availability of the 280zx masters.
Cheers guys
Shorter 7/8" master cylinder for b210/180b booster
Re: Shorter 7/8" master cylinder for b210/180b booster
1965 Bluebird 410
1976 Yamaha RD50
1976 Yamaha RD50
Here is a couple of pics of the 280zx Master mounted up. Has between 15-20mm clearance, plus could possibly get a bit more replacing the reservoirs on one of these masters with a couple of round ones (any reason you can't do this?).
Keen to hear any thoughts on whether this should be sufficient clearance.
Jeremy
Jeremy
1965 Bluebird 410
1976 Yamaha RD50
1976 Yamaha RD50
