Wiring Ca18det into B310 sunny
all your DIY needs
CASunny
Post by CASunny »
So have got to the part i have been dreading for awhile...
Im starting with relays for the fuel pumps.
Running a external Walbro 500hp pump and a Carter lift pump to fill the surge tank.
I can run both off 1 relay?
I have a 5pin relay( 30,85,86, and two 87s)
Is the 30pin fused from the battery with a 20a fuse using 10g wire,
85 pin is earthed with a lesser gauge wire,
86 pin is fed from the the output of the ecu that usually feeds STD relay? (number 18 on the ecu harness,
87 pins both feed pumps positive with 10g?
Am i missing anything?
I know i also need a relay and fuse for the ecu?
Please help me!!!
Cheers guys
Datto_610
aka: Greg
Re: Wiring Ca18det into B310 sunny
Post by Datto_610 »
Pm Dan aka datsunboy he is the man when it comes to wiring also knows plenty about CA's and datsun's!
detdat
aka: Cam
Post by detdat »
Hey
You could get away with just one relay, but if it was me I'd use a relay for each pump.
With the actual wiring of the relay:
Are you using a standard computer?
If so the ecu pin for the fuel pump is active low, meaning it switches that pin to ground to turn the relay on.
So you need to change your '85 pin to a ignition source ( 12v when the key is on etc)
Hope thats helps,
I live in Wellington, if you get stuck more than happy to come give you a hand.
cheers
Cam
CASunny
Post by CASunny »
Datto_610 wrote:Pm Dan aka datsunboy he is the man when it comes to wiring also knows plenty about CA's and datsun's!
Hi Greg, sweet ill flick him a Pm...
Cheers mate
CASunny
Post by CASunny »
detdat wrote:Hey
Hope thats helps,
cheers
Cam
Hey
Yep using standard Ecu with a dirty Speedlab chip at the moment to get it running..
Brilliant, thought something didn't add up.
Helps for sure, cheers Cam.
Ill let you know if i get proper stuck...
Caallym
