Hi everyone we (my brother and I) have a couple of projects under way, our latest addition being a 72 Z18ET 1200 Coupe in need of some attention. As we are new to this site will see if I can figure out how to post some pics to illustrate
Mark
7 Coupe's Projects and Cars
Datsun Brothers
Re: 7 Coupe's Projects and Cars
And the not so good view
Our first job is to get that wheel free so we can steer our new baby, then we can get it into the Coupe repair den.
Or plan is to chain the crushed bit to a tree and pull from behind with the 4WD (as any good Kiwi would do
Engine is intact and still running but it is a bit tighter than in this pre crash pic though the radiator doesn't hold water for long
Datsun Brothers
Looked to be a fair price for that car, looks like it will need a pretty good front cut grafted on most likely aye.
wow snapped up and already on here as a project, good luck with the repairs, take plenty of pics and welcome to the site.
We thought so on both of those,
Our Dad was an old school panel beater and would have repair what was there but I'd says that's beyond us
Its near impossible to move around how it is so will give it a stretch just for Now
Done this before many years ago so fingers crossed
(Coupe 1 from about 30 years ago
Datsun Brothers
Thanks2 doors wrote:wow snapped up and already on here as a project, good luck with the repairs, take plenty of pics and welcome to the site.
And I thought that might be the case, would appreciate the link to that
Edit, just realized you all saw it on TM (as cant see it as a build on the site anywhere)
We are in no hurry to fix it (steady as she goes) and expect a few K to go in before its a runner again, though guess I may have to look at what else is in my shed that can be sold to move things along a little
Datsun Brothers
Ok so we started stage 2 of the project yesterday (Get Coupe 7 movable)
Its hard to move something with the wheel wedged at full lock and the tire flat
Will continue after I've had my Sunday afternoon Superbike TV fix
Datsun Brothers
We attached a tow strop to the lower suspension arm and proceeded to jolt the car forward with another vehicle.
It barely moved, so eventually we had to release the front arm brace and sway bar and then after several tries the wheel was free
Datsun Brothers
Our goal for the day was just be able to move C7 around so we then tried to fit a spare 13" Skinner non punctured C6 Datsuns spare wheel but the S13 calliper and even the disc were to big so we had to remove them and tie the calliper up on the guard with a steel spacer plate between the brake pads so we could still apply the brakes for the other wheels.
Datsun Brothers
We tried to start the Z18ET motor after this but perhaps a cross between to a weak battery and the fact it hadn't been running for a year or so, she was a no go which meant that once we had taken the C6 A15 coupe project car for a quick spin around the block to warm it up,
we then hitched C7 up and towed it into the Garage for safe storage ready for Stage 3 work
Datsun Brothers
