1985 GB122 1200 Sunny Ute
Re: 1985 GB122 1200 Sunny Ute
Glad to see the warrant happened! As for the other comments........ I have come an extremely long way. No rush for the bump stops, it's not like the coupe is gonna be going anytime soon hahahaha. I can always pick them up easter weekend anyway as I'm planning a visit
1972 1200 coupe KB110
- Tony_Whenua
Took the ute for a drive today ... Seems like quite a battle keeping it on the road without the strut spacers but still love that Datsun feel.
Thinking I might put them back in but seems a bit of a waste of the wheel alignment I just got.
few other things..
- seems to be running rich and can smell small amounts of fuel occasionally.
- Seems to turn really easily left but is tight to the tight.
- Also seems more movement on the wheel before it actually turns the wheels.
looking forward to Rakaia
few other things..
Fitting strut spacers will only need the toe-in adjusted. The castor/camber change if any will be even on both sides, so no worries.Tony_Whenua wrote:quite a battle keeping it on the road without the strut spacers ...
- Tony_Whenua
good news I'll put them in on Wednesday ... looking forward to Rakaia ... anyone free to do a timing/tapets check when I roll into Chch?ddgonzal wrote:Fitting strut spacers will only need the toe-in adjusted. The castor/camber change if any will be even on both sides, so no worries.Tony_Whenua wrote:quite a battle keeping it on the road without the strut spacers ...
- Tony_Whenua
Re:
how do I go about that?Datto_610 wrote:Sounds like play in the steering box which is why the steering wheel turns a few times before the actual wheels do. Might be able to adjust the steering box a bit to get rid of the play but you only go so far if your steering box is pretty old and shagged.
- Kitch
good work - glad to see you have ute back on the road.
Adjust the steering box as follows;
http://datsun1200.com/modules/mediawiki ... Adjustment" onclick="window.open(this.href);return false;
Tappets are really easy!
we could do them at the Rakaia gorge park up.
14 thou hot, and rule of nine. (I'll explain on the day)
- Tony_Whenua
Yeah I'm going to give it a go tonight. Been suggested to drain the fuel in the carb possibly and see if there is any water in it.Bartman wrote:Tappets are really easy!
Wanted to check timing but they were $110 from Repco!
So tonight I'll check/do:
- Tappets (comments about how are somewhere earlier in this profile)
- Strut spacers
- Dwell reading and points
- Clean filter etc
- look into changing diff oil ... seems noisier than usual so maybe thought could change it out??
