B310 sr20 conversion
Sunny side up
- Newbie
Hey am dropping a sr20 de into my b310 sunny am wanting to convert the engine from dizzy cap to coil packs. anybody on here that has done this before any advice would be greatly appreciated....cheers
- tlssunny
- aka: jesse
Re: B310 sr20 conversion
pmd...........
Since the CAS and the Dizzy mount different,
You'll be wanting to mount the CAS disk and pickup into the Dizzy case,
I did this on a VG there should be pics on my thread if interested on how i went about it.
It's pretty straight forward, but i did have to make some spacer washers.
Is it a rwd sr20de? If so you can convert it to running DET cas and ecu with a daughter board to tune it. S13 sr20det ecus are a little hard to find, but are the easiest one to use and retune.
