Brendan's Garage Sale!!!
Sell stuff
mint16
aka: Brendan
Post by mint16 »
Lots to sell, lots of goodies, lots of bargains!!!
Nissan E15 electronic dizzy, unmodified, missing the dizzy cap $60
A-series waterpump pulleys $5 each
Datsun toolbag, missing flat blade screwdriver and wheel chocks $30
Datsun Sunny B310 rear chrome bumper rego plate lights, excellent condition just need a clean/polish, lenses are mint $40
Guard indicators, suitable for 1200s, round headlight B310 Sunnys, good condition $30
1200 or 120Y engine mounts, no cracks $5 each
A-Series oil caps, most need a good polish $5 each
Sunny B310 interior light lense, no cracks or damage $5
DATSUN1500 badge, MINT and METAL $40
Sunny B310 Coupe round headlight gauge cluster with rev counter and wiring $30
A-Series fuel pumps, good working order, to suit A12 (late) A14 A15, right to suit late vanette C22 $10 each
Ignition lock and key from 1972 1600 P510 $10
A-Series thermostat housings, left to suit all models, right to suit 1200 early A12 $10 each
L-Series oil cap $5
L-Series clutch release carriers (bearings stuffed, can remove before sale) $5 each
1600 P510 engine mounts, good solid condition $30 pair
A-Series bellhousing lower cover $5 each
A-Series full engine-to-gearbox spacer plate $10 each
A-Series gearbox speedo drives, to suit 4 speed $10 each
1200 and 120Y interior lights, some heat cracking, one lense $5 and one lense with holder $10
1200 sun shades, one needs recovering $20 pair
1200 and 120Y light switches, variety of fasteners to choose from, one switch has had some wire modifying $10 each
Datsun rear guard badge for 1200 Coupe, broken in the middle, still has all pins $20?
Gearbox crossmember $offers
Custom gearbox crossmember for 5 speed into 1200 $40
35 amp alternator for A-Series $20
1200 black ashtray and steering column surround, surround has one edge broken off $10 each
280zx caster rods $30
Alternator adjuster brackets, top right is L-Series $5 each
180B 610 window winders, can also be used in 1600 P510, Sunny B310, any models that use the hidden fixing clip $40 set
72 Datsun 1200 Wagon
mint16
aka: Brendan
Re: Brendan's Garage Sale!!!
Post by mint16 »
5 speed in 1200 crossmember, two oil caps, and A-series bellhousing lower covers SOLD!!
dattoboy
Datsun Nutter
aka: Bede
Post by dattoboy »
Ill buy the L series oil cap Brendan.
R3spct
Datsun Dreamer
Post by R3spct »
Lower cover x1
Ill get one of these if available
5 Speed gearbox mount
2nd dibs on this just incase, or can you post a couple more pics for design inspiration?
mint16
aka: Brendan
Post by mint16 »
dattoboy wrote:Ill buy the L series oil cap Brendan.
Done.
mint16
aka: Brendan
Post by mint16 »
R3spct wrote:Lower cover x1
Lower covers all sold sorry.
Can get you more pics of custom 5spd mount.
Tony_Whenua
Post by Tony_Whenua »
mint16 wrote:Can get you more pics of custom 5spd mount.
Must be someone out there able to replicate this? I'd be after one too if that's a possibility?r
R3spct
Datsun Dreamer
Post by R3spct »
I dont mind making a couple if i need to make one.
Ive also heard you can drill the welds out on the chassis mounts and move them in the trans tunnel, this way means from a wof and cert point of view the mount isnt modified or fabricated so isnt such a issue.
mint16
aka: Brendan
Post by mint16 »
If you moved the chassis mounts, the 5 speed rubber mount is different in how its bolted to the xmember (and gearbox) so youd still need to modify the 4 speed xmember to suit. I did this on my 1200 ute back in the day.
twofortyz
Post by twofortyz »
is the stock B310 gearbox crossmember still available?
Thanks
