Nissan E15 electronic dizzy, unmodified, missing the dizzy cap $60
A-series waterpump pulleys $5 each
Datsun toolbag, missing flat blade screwdriver and wheel chocks $30
Datsun Sunny B310 rear chrome bumper rego plate lights, excellent condition just need a clean/polish, lenses are mint $40
Guard indicators, suitable for 1200s, round headlight B310 Sunnys, good condition $30
1200 or 120Y engine mounts, no cracks $5 each
A-Series oil caps, most need a good polish $5 each
Sunny B310 interior light lense, no cracks or damage $5
DATSUN1500 badge, MINT and METAL $40
Sunny B310 Coupe round headlight gauge cluster with rev counter and wiring $30
A-Series fuel pumps, good working order, to suit A12 (late) A14 A15, right to suit late vanette C22 $10 each
Ignition lock and key from 1972 1600 P510 $10
A-Series thermostat housings, left to suit all models, right to suit 1200 early A12 $10 each
L-Series oil cap $5
L-Series clutch release carriers (bearings stuffed, can remove before sale) $5 each
1600 P510 engine mounts, good solid condition $30 pair
A-Series bellhousing lower cover $5 each
A-Series full engine-to-gearbox spacer plate $10 each
A-Series gearbox speedo drives, to suit 4 speed $10 each
1200 and 120Y interior lights, some heat cracking, one lense $5 and one lense with holder $10
1200 sun shades, one needs recovering $20 pair
1200 and 120Y light switches, variety of fasteners to choose from, one switch has had some wire modifying $10 each
Datsun rear guard badge for 1200 Coupe, broken in the middle, still has all pins $20?
Gearbox crossmember $offers
Custom gearbox crossmember for 5 speed into 1200 $40
35 amp alternator for A-Series $20
1200 black ashtray and steering column surround, surround has one edge broken off $10 each
280zx caster rods $30
Alternator adjuster brackets, top right is L-Series $5 each
180B 610 window winders, can also be used in 1600 P510, Sunny B310, any models that use the hidden fixing clip $40 set
