r180 27 spline side shafts/ stub axles
tlssunny
aka: jesse
Post by tlssunny »
so for my bluebird conversion iam needing a pair of 27 spline stub axles 3x2 bolt pattern. if anybody has lying around or point me in the correct direction
thanks
tlssunny
aka: jesse
Re: r180 27 spline side shafts/ stub axles
Post by tlssunny »
does anyone know if a 27 spline side shaft from a r180 diff out of a s13 will work??? have spent plenty of time researching it at work but cant find a definitive answer........
my 910 has 3x2 axles so I don't really want to change them etc
thanks
Datto_610
aka: Greg
Post by Datto_610 »
It should?? The R200 inputs from shortnoses fit the longnose housings so I would assume the R180's would. Either way you're going to have to get the axle shortened and resplined if you want them to be like the ones in the back of my car. But if you have that lsd center you were telling me about factory axles may work???
tlssunny
aka: jesse
Post by tlssunny »
iam pretty sure I have got it sorted now I will just need to shorten both axles 20mm rougly. wont know exactly til I get it all bolted in though
Datto_610
aka: Greg
Post by Datto_610 »
Sweet
85_Z31
Datsun Master
Post by 85_Z31 »
Jessie was the R180 a datto one or a subaru one ?
I'm doing one for DJ but haven't counted the splines yet.
tlssunny
aka: jesse
Post by tlssunny »
85_Z31 wrote:Jessie was the R180 a datto one or a subaru one ?
hey james, mine is a Subaru suretrac lsd r180 which has 27teeth. iam getting a r180 open diff from another Subaru but unsure of teeth count yet
my research tells me there is 2 Subaru options on a r180 which are 25 or 27 teeth but I could be wrong as the google can be wrong
85_Z31
Datsun Master
Post by 85_Z31 »
Cheers Jesse
That makes reasonable sense there is 2 sizes of spline.
I'm thinking that the Mechanical Subaru diffs like from an STI would be the 27 spline and perhaps the others are the standard 25 spline ?
Or maybe the R160 Diffs are 25 spline and R180's are 27
tlssunny
aka: jesse
Post by tlssunny »
I have read so much different stuff and so much the contradicts itself that I don't want to confuse any more people etc from what I can gather Subaru had 2 r180 options they are 25 (early) and 27 (late) but unsure of the date of crossover think its early 00's
Nissan r180 seems to be 27 or 29 (could be wrong there) i read some stuff that said NO Nissan had a r180 with 27 teeth but then i would read that they all had 27 teeth
r160 I think may only be 25 but again I could be wrong as i ready so much bullshit but no one could really pin point this is this and that is that so i cant confirm or deny my information
i only really read up on the Subaru r180 stuff and not much into the Nissan or r160 stuff.
is this for daniels white 280?
i have brought a complete Subaru r180 open head, a complete Nissan 180 head and a r180 suretrac lsd so should be able to work something out with the 3 lol
85_Z31
Datsun Master
Post by 85_Z31 »
They can be a but awkward to take apart.
I will take some photo's to show you a trick to get the center out of the housing. It confused the crap out of me the first time i took one apart. You sort of have to hold it just the right way and rotate it gets stuck. The manuals don't show it very well.
