This article came up in my feed.
Might be helpful to someone
http://thegarage.jalopnik.com/heres-how ... 7377704245#" onclick="window.open(this.href);return false;
Replace your brake lines.
510BRE
- Area Reps
- aka: shane
Re: Replace your brake lines.
also helpfull .... buy cupronickel brake line it wont rust any time soon . and can be purchased from bnt aye brock .....
- tlssunny
- aka: jesse
or go straight to where they buy it from dasko
- brocky41
- aka: Brocky
We dont get ours from Dasko aye
A handy tip is to save up and reuse as many of the non damaged threaded fittings as you can.
Getting new ones are expensive, go to pick apart and get a whole heap of the good cheap jap ones.
I'd add that most of those cheap flarers are total junk.
Spend the money on a really nice one if you can - the Sykes Pickavant one is a dream to use.
You can buy the greeny-coloured OEM style coated bundy tube on ebay now too.
I'm going to be doing this soon. Can anyone recommend using steel or copper bundy tubing? I can source both through my work. Also does anyone know what thread a '79 620 will use?
Sweet as, my supplier does a copper nickel version. Also, just curious will that need to be certified?
