Replace your brake lines.
torqued
aka: Adam
Post by torqued »
This article came up in my feed.
Might be helpful to someone
http://thegarage.jalopnik.com/heres-how ... 7377704245#" onclick="window.open(this.href);return false;
510BRE
Area Reps
aka: shane
Re: Replace your brake lines.
Post by 510BRE »
also helpfull .... buy cupronickel brake line it wont rust any time soon . and can be purchased from bnt aye brock .....
*cough* and Appco.... *cough*
tlssunny
aka: jesse
Post by tlssunny »
or go straight to where they buy it from dasko
brocky41
aka: Brocky
Post by brocky41 »
We dont get ours from Dasko aye
85_Z31
Post by 85_Z31 »
A handy tip is to save up and reuse as many of the non damaged threaded fittings as you can.
Getting new ones are expensive, go to pick apart and get a whole heap of the good cheap jap ones.
broke
aka: John
Post by broke »
I'd add that most of those cheap flarers are total junk.
Spend the money on a really nice one if you can - the Sykes Pickavant one is a dream to use.
You can buy the greeny-coloured OEM style coated bundy tube on ebay now too.
82m
Regular
Post by 82m »
I'm going to be doing this soon. Can anyone recommend using steel or copper bundy tubing? I can source both through my work. Also does anyone know what thread a '79 620 will use?
I'm pretty sure you can't run full copper lines got to use copper nickel bundy tubing. Thread should be m10x1 like most Nissans and Datsuns
82m
Regular
Post by 82m »
Sweet as, my supplier does a copper nickel version. Also, just curious will that need to be certified?
