VG30 510
Datto_610
aka: Greg
Post by Datto_610 »
Wasn't aware there was any differences? Pretty sure the pad is the same part number up until series 8. Are your rims hitting the calipers?
torqued
aka: Adam
Re:
Post by torqued »
chris_g1 wrote:Nice mate good to see the progress.
Thanks bud, good to be back into it.
Datto_610 wrote:Wasn't aware there was any differences? Pretty sure the pad is the same part number up until series 8. Are your rims hitting the calipers?
Na, it is my wheels. My mounting service is flush but yours has a concave, if that makes sense?
Brought some S7 before should be the go.
Fingers crossed
torqued
aka: Adam
Re: VG30 510
Post by torqued »
Thinking of selling off the 235/50/15 rears R888s.
And going to a 225/45/15 Nitto NT01 for the ass, keeping the same size on the front 205/50/15
Anyone had any wet weather experience with the Nittos?
Anyone wanting some brand new only fitted 235/50/15 Toyo R888s?
Re: VG30 510
I'm not sure exactly which ones he had, but a mate of mone had some nittos on his car. He was stokes with how they performed. traction control kicked in bugger all.
but they were fucked in no time. 300kw life.......
torqued
aka: Adam
Re: VG30 510
Post by torqued »
The KMs doesnt really worry me, If i could find in a semi decent road tyre that would be ideal but it is more the profile i am after.
brocky41
aka: Brocky
Re: VG30 510
Post by brocky41 »
torqued wrote:The KMs doesnt really worry me, If i could find in a semi decent road tyre that would be ideal but it is more the profile i am after.
Nitto's apparently all good - lots of guys in states use them. Id just watch it in the rain on chip seal, could get a bit dicey. Id try get the same for the front if i was you.
torqued
aka: Adam
Re: VG30 510
Post by torqued »
So the S4 ( Gen2 ) RX7 Calipers just were not going to work,
After a few modifications to the orginal bracket and some Re-Jigging.
I managed to get the Batman RX7 calipers in a location where the wheel would spin.
As you can see on the last few pics i am playing with fractions in regards to clearance, but i think it is going to work.
broke
Datsun Addict
aka: John
Re: VG30 510
Post by broke »
Nice work Adam,
Now go fit that swaybar!
Datto_610
aka: Greg
Post by Datto_610 »
So what was the difference between the two calipers?
torqued
aka: Adam
Re: VG30 510
Post by torqued »
The offset is slightly different,
I can grind more from the outside surface because the fluid bridge is less pronounced and transferred more horizontal.
Pads are the same.
The key factor was the fluid bridge meant i had a few extra MM to play with
