Is there more options for the board theme that just this one?
I can't tell which topics have replies easily.
change theme?
change theme?
datsunboy
- aka: Dan
Re: change theme?
There used to be.
Once the forum has all been shifted etc ginge was going to take suggestions for mods like this
- gingofthesouth
- aka: Ging
Re: change theme?
Sorry, been tied up with family and work commitments. I'll try get st the themes Monday.
- gingofthesouth
- aka: Ging
Re: change theme?
I have added another theme that makes it easier to see the new posts called pro-flat.
I haven't really tested it properly yet but see if it works well enough for you otherwise I will install some others.
You can also browse through available styles here:
https://www.phpbb.com/customise/db/styles-2
If you find any you like I can add them for you.
datsunboy
- aka: Dan
Re: change theme?
Thanks ging.
We had a custom one previously is that able to come back?
- gingofthesouth
- aka: Ging
Re: change theme?
I doubt it but can check it out. One of the big updates of the forums besides from a security point of view 9and attachment uploading) is the move to a responsive (aka changes how it looks based on the size of your window aka mobile friendly) design. The old theme may not allow the website to be responsive and possibly not forward compatible regardless.datsunboy wrote:Thanks ging.
I need to put a copy of the old forums up so I can check out the old design elements and see if I can just recreate it.
