change theme?
please list any ideas or problems you are having here
change theme?
Is there more options for the board theme that just this one?
I can't tell which topics have replies easily.
datsunboy
aka: Dan
Re: change theme?
Post by datsunboy »
There used to be.
Once the forum has all been shifted etc ginge was going to take suggestions for mods like this
gingofthesouth
Site Admin
aka: Ging
Re: change theme?
Post by gingofthesouth »
Sorry, been tied up with family and work commitments. I'll try get st the themes Monday.
gingofthesouth
Site Admin
aka: Ging
Re: change theme?
I have added another theme that makes it easier to see the new posts called pro-flat.
I haven't really tested it properly yet but see if it works well enough for you otherwise I will install some others.
You can also browse through available styles here:
https://www.phpbb.com/customise/db/styles-2
If you find any you like I can add them for you.
datsunboy
aka: Dan
Re: change theme?
Post by datsunboy »
Thanks ging.
We had a custom one previously is that able to come back?
gingofthesouth
Site Admin
aka: Ging
Re: change theme?
datsunboy wrote:Thanks ging.
I doubt it but can check it out. One of the big updates of the forums besides from a security point of view 9and attachment uploading) is the move to a responsive (aka changes how it looks based on the size of your window aka mobile friendly) design. The old theme may not allow the website to be responsive and possibly not forward compatible regardless.
I need to put a copy of the old forums up so I can check out the old design elements and see if I can just recreate it.
Re: change theme?
Thanx Ginge. Appreciating all the effort and knowledge.
