classicdat wrote: ↑Wed Jan 15, 2020 11:32 amI fully hear you, had a go at my 1200 for a couple of weeks, apart from polished metal and bog splatter you can't tell I even started, think I need some tuition.
scooters 260C H330
Re: scooters 260C H330
I actually got a good tip just yesterday. You tape over the bog when your happy with it. Then keep working away at the rest. It stops you sanding the stuff out you don't want to sand out. Well..... he had me convinced anyhow.
Time for a update.
It's up and running getting about just fine. Just a bit of rub to deal with on the back. Full of fuel and kids it's bad enough to have to sort.
a few photos. Went and hung with the Nelson Datsun Crew.
Wass all G.
Wass all G.
The new wheels and tyres ment that the gearing was up the shit. Howling pritty hard on the open road a few more RPM than what works for me.
Aquired a 3.7 diff. Stripped it. Noticed a bit of old historic damage. I suspect something went threw it way back when.
Put some new bearings in changed it. Gearing is perfect and the spedo is about bang on. Just set the diff up so it stayed away form the damaged bit as much as I could.
