l18 into 1600....some advice
Re: l18 into 1600....some advice
Would you sway the driveshaft for one of your gearbox Xmembers? Mine was butchered by the neanderthols who owned the car before me.
nosebleed
Datsun Dreamer
Post by nosebleed »
not 100% sure if the spare is a datto one, just looks abit different, will check tomorrow and let you know though.....
found a few parts in the boxes are actually toyota bits,theyv been dumped
I DO ALL MY OWN STUNTS
nosebleed
Datsun Dreamer
Post by nosebleed »
510BRE wrote:fitting a l18 will need stock 1600 sump and oil pickup with cross member in stock position .... tell us the number on side off gearbox man ......sounds like you got a 71b gearbox this should fit your l18
i cant seem to find a number on the box anywhere... theres a 6 by the looks..
where would the number be?
nosebleed
Datsun Dreamer
Post by nosebleed »
Bartman wrote:Would you sway the driveshaft for one of your gearbox Xmembers? Mine was butchered by the neanderthols who owned the car before me.
spare crossmember looks like a mazda one... one side is flat and the other side raises up then angles down sort of like a s4 rx7...
MR1200
Post by MR1200 »
torqued wrote:you really have no idea do you?
I reckon give it a month and the your whole car will be back on trade me.
wat the hell??? stop bein a hater! wats wif baggin on sum one for no reason
PAINT THE ROADS BLACK !!!!!
160jsss
Post by 160jsss »
i could hook you up a 4 speed if you want
Violet - ??????
nosebleed
Datsun Dreamer
Post by nosebleed »
sweet how much?
160jsss
Post by 160jsss »
How does 40 bucks sound we out in Kirwee so could pick it up on the way in or out of CHCH
Violet - ??????
nosebleed
Datsun Dreamer
Post by nosebleed »
sweet, means ill have to go through darfield...havent been that way for years..
has it got a fork,shifter,slave and throw out bearing?
160jsss
Post by 160jsss »
will have a look tomorrow no slave i need one two but cheap to buy new the one on the fj may work
Violet - ??????
