porting gaskets?
aka: leppa
Re: porting gaskets?
Post by dirtyleppa »
im not too bad at it man, i could give it a go. is it blowing because it doesnt match the ports or maybe the manigold is not 100% flush with the head?
Dattodevil
aka: Damo
Post by Dattodevil »
Go to shuk, and invest the money in the right gasket with flame rings. I have used a die grinder in the past but it tends to leave shards on the edges, and it comes out a bit average.
Jabo
aka: Jasper
Post by Jabo »
I recommend a good sharp set of tin snips
I think it blew because the tops of my zhorst ports have been made curved. The gasses will have come up and hit the gasket, and cause the other material to be forced out. On the two end ports, you can see the metal where the gas has blown away the other material where it was in the flow path.
Josh
aka: SeEn-ThE_lIgHt
Post by Josh »
I use a dremel die grinder with teardrop tip, and im fucking good too.
haha
1972 B110 Deluxe~ Daily
1965 P410~ Wifey daily
