dan1200sss ca18det datsun 510
dan1200sss
Datsun Driver
Re: VG and SR killer 510
Post by dan1200sss »
na not much at all, like it was painted a good 5 years ago now and the only bubbles have come through are in the bottoms of the front guards and below the tail lights. allthough theres bound to be some little bits brewing away here and there that hasnt show itself yet but as the other saying goes..ill cross that bridge when i get to it. im just glad i know how to patch rust now days so it isnt a drama to sort out. the next mission will be too drop the subframe out and replace all the cv boots, re-grease cvs, strip the R200s sometimes VLSD and replace centre with something mechanical, do you know if GTR r200 diffs are any good? like as good or close to a 2way mechanical?
torqued
aka: Adam
Post by torqued »
dan1200sss wrote:na not much at all, like it was painted a good 5 years ago now and the only bubbles have come through are in the bottoms of the front guards and below the tail lights. allthough theres bound to be some little bits brewing away here and there that hasnt show itself yet
Just the standard place then. Its strange that the rust around the tail lights. Ive seen a few blow out there.
dan1200sss wrote:the next mission will be too drop the subframe out and replace all the cv boots, re-grease cvs, strip the R200s sometimes VLSD and replace centre with something mechanical, do you know if GTR r200 diffs are any good? like as good or close to a 2way mechanical?
Not a clue dude, But i would just bite the bullet and go Mech anyway. if its just for Heli's you would be better to
I've heard that the GTR CLSD's use a unique input shaft spline. So if you got one of those, you'd need the input shafts to match too.
85_Z31
Post by 85_Z31 »
I Purchased the guts of a GTR R200 CLSD for the clutch plates
If its from an R32 GTR i can confirm the following
These are 2 ways units with symmetrical ramp angles
The Clutch Plates and other replacement parts are compatible with the older R200 LSD's
The Splines count is different to the typical 29 Spline used on Nissan input shafts
As far as i can tell the guts of the R32 GTR lsd is identical to the older DR30/Z31/early style R200 style CLSD
the only difference I am aware of is the Side gears are definitely a different spline
I sighted all of these changes when building my CLSD, the only part of the GTR lsd i did not see is the housing as i used an LOM59 housing which is from god knows what.
dan1200sss
Datsun Driver
just purchased a r200 NISMO 2way LSD tonight, its off a mate of a mate out of his imported 200sx donor car. gonna get that apart one night this week and pull my long nose r200 out and apart. also need to track down some 3x2 stub axels to suit it aswell asap as its 5x1 currently
This sounds like it's all coming together for you Dan, would be great to see it at Ruapuna for the track day.
dan1200sss
Datsun Driver
yeah i really need to get stuck into the front end before it goes near a track, need to work out what the best coilover/adjustible setup will be for the front. not to phased about the rear end at the mo as it corners and slides well as it is
dan1200sss
Datsun Driver
For any one wanting to know how to spot a r200 mechanical LSD and work out if it's 1.5 or 2way heres a diagram.
dan1200sss
Datsun Driver
Also scored some nice cheap 14x8 and 14x7.5 type A SSR long champs the other day. Fairly good nick other than the paint thats been sprayed on the centres and the horrible tyres that are on them, they even still have stickers on the backs with sizes etc.
niccy
Datsun Driver
Post by niccy »
dan1200sss wrote:Also scored some nice cheap 14x8 and 14x7.5 type A SSR long champs the other day. Fairly good nick other than the paint thats been sprayed on the centres and the horrible tyres that are on them, they even still have stickers on the backs with sizes etc. and because im succcch a good bf, im going to sell the 8s to my gf :)
