help a poor african out
its the blue thing
thanx hayden, ill get hold of you some timekartboy wrote:Hey man. I have got one here taking up space on my garage floor if you want to try it some time to see if it fits
ive got twin SU carbs here that i may fit. im not doing it to gain any more performance, im just not a massive fan of having no filter on the engine like i used tomint16 wrote:im pretty sure the vanette intake pipe wont fit on your carb, as your carb has a much bigger intake diameter.
it was never fitted to any other a-series vehicles.
aesthetically its not good.
what about airflow volume compared to stock airbox? just a thought.
id rather see you fit a single sidedraught carb or a downdraught weber carb, i think youd get a better result.
i think a weber 32/36 from a ford 2L would be a good upgrade, and could be quite affordable.
i think all the effort involved fitting the pod setup wont be worth it. unless you do it on maximum cheapness for experimentation, then go hard!
