Hey guys, Need to know from which model this engine come from? If it's from 1200 coupe GX5 (KB110) should it be with a 5speed gearbox? But this is only 4 speed. And can somebody tell what is the spec of this engine. Like the HP, is it a better engine from the A12 single carb.
A12 twin carb.
Thanks,
Affa
A12 Engine
- aka: Affa
A12 Engine
Click Here For > My Other Parts
- mint16
- aka: Brendan
Re: A12 Engine
looks to be a mid dizzy a12, probly from a 120y or sunny 310.
1200 coupe gx5 a12s will have the front mounted dizzy.
Re: A12 Engine
It might have a GX head though. Unfortunately you wont be able to tell without removing the rocker cover.
- aka: Affa
Re: A12 Engine
But the guy told me it's from a KB110 body. Maybe the Japanese has change the gearbox. What they called it Dogleg close ratios.mint16 wrote:looks to be a mid dizzy a12, probly from a 120y or sunny 310.
Thanks guys, But if I open the rocker cover, what is the different on it?Bartman wrote:It might have a GX head though. Unfortunately you wont be able to tell without removing the rocker cover.
Re: A12 Engine
it will say "nissan Japan" under the rocker cover. There will be no "H" number. (IE H72, H75, H89 etc)
- mint16
- aka: Brendan
Re: A12 Engine
As far as I know B110s A12 motors never came with mid mounted distributors.A_FC3S wrote: But the guy told me it's from a KB110 body. Maybe the Japanese has change the gearbox. What they called it Dogleg close ratios.
Is there a factory option close ratio 4spd????
- aka: Affa
Re: A12 Engine
That is why I'm asking you guys? I have no idea and less knowledge on this Datsun engine. I need to have as much input B 4 I buy this engine.mint16 wrote: As far as I know B110s A12 motors never came with mid mounted distributors.
- aka: Affa
Re: A12 Engine
Will check out and see what is written on it.Bartman wrote:it will say "nissan Japan" under the rocker cover. There will be no "H" number. (IE H72, H75, H89 etc)
