Rotary into 1600
510_nz
Rotary into 1600
Post by 510_nz »
Has anyone done this? I've seen a few for sale. Just wondering how much work is involved. Obviously the cross member, engine and gearbox mounts will need work. Just wondering if the trans tunnel will aswell? Had a look online, and there seems to be very little info this conversion.
Thanks.
RX4 Coupe
1600
1600SSS Project (Complete, looking to sell)
torqued
aka: Adam
Re: Rotary into 1600
Post by torqued »
the tunnel needs work....
...and i say no becuase rotorys are horrible motors
I have an Xmember to fit a rotor into a 510, But I don't know weather or not it would pass cert or not. You'll also need to enlarge your transmission tunnel. As well as the obligatory modifications to the wiring loom.
Where abouts are you?
Dattochriswagon
Post by Dattochriswagon »
And ya need lots of money for gas and rebuilds evry few hours :D :D
510_nz
Post by 510_nz »
I'm in Auckland. What engine is the xmember set up for?
RX4 Coupe
1600
I'm not sure. It came with my 510 when I bought it. The previous owner had begun converting it and given up.....
nzdatman
Post by nzdatman »
Bartman wrote:The previous owner had begun converting it and given up.....
Good. Rotary engines are cool in Mazda Rotarys. Nissan have enough good engines to choose from. but hey it's your car.
OUTLAW
Post by OUTLAW »
Either way ,A SR/FJ conversion will set you back a fear amount of dollars as will a rotary conversion ,upto you what way you go but it won't be cheap .
MODS:
Gearbox xmember
Engine xmember
and some slight relief to the firewall for the clutch fork on the top of the gearbox
Other than that it would only be small stuff like wiring-exhaust ect
IIIRII
Regular
Post by IIIRII »
Rotaries are THE easiest engine to fit into anything
sr1600
aka: Mark
Post by sr1600 »
Yes they are easy to fit in anything, but that also depends which way your gonna go??
ported motor NA is by far the easiest but the motors are pretty expensive for a low k or rebuilt one + plus the gear youll want IDA Flywheel gearbox
turbo standard motor are easy and cheap but you dont actually know what your gettin but the front plate with have to be changed
Only difference between a 13b and a 12a is its 20mm longer and either way you will need a 12a front plate to mount it
