last night i removed the rear arms, found two different rear springs which is the answer to the rear sagged on one side, one rear arm bumpstop missing, one gas shock and one factory oil shock. christ, i really havent touched this car since i bought it!!!
stripped arms ready for stub axle removal and r31 disc brake conversion.
today during work hours, i pressed out the stub axles, without damaging the axle nut threads
tonight i removed the diff and crossmember, as well as the 120y floor handbrake i had installed (which will no longer be used).
tomorrow during work hours ill remove the bearings from the rear arms, might even push out the rear arm bushes too, and remove the companion flanges from my s12 rear arms for the cv axle conversion.
shane 510BRE is currently scalloping my crossmember for an r200 longnose fitment, hes already enlarged the exhaust hole to 4inchs, thanks dude!!
not too distant future progress:
-complete r31 rear disc conversion
-make rear crossmember adjustable
-modify 1600 moustache bar to accommodate r200 longnose
-fit reversed 69 front crossmember in place of reversed 70 crossmember
-fit 1600 steering box/column in place of 180b steering box + column
-fit r31 front struts with cusco camber plates and adjustable platform suspension
-mount sr20 longblock properly with modified s13 engine brackets and 1600 engine mounts
-mount gearbox and modify 1600 crossmember
