Changing diffs in my 1600 after the trackday prompted the end of the r160
The reason i never got it changed and ready for the Akaroa run was when i poped the axles out i noticed different splines.
My 1600 had the u/j type end with the bolt running through the centre bolting it into the diff head.
The r180 ive got has 4 bolt flanges with two splines on the shaft and circlip at the end to hold it in the diff head.
Havnt had anything to do with the rear ends in these before so after a bit of info please.
It has a leone r160 in it, do the 1600s have the u/j type with bolt running through the centre from factory or has it had axles from the leone fitted? Is there an axle combo that will go in without getting sometihing made?
Any info would be great please.
Thanks
