240z Parts
LYDOS240z
240z Parts
Hey, I need a left rear axle and does anyone know where I can get electronic conversion kits for my dizzy?
Re: 240z Parts
try this guy, who must be parting one out:
http://www.trademe.co.nz/Members/Listin ... ber=403761" onclick="window.open(this.href);return false;
Re: 240z Parts
As for the electronic dizzy kit,theres few on trademe.they work well and easy to install.i got it on my datsun.
I guess you after the hub assembly
Re: 240z Parts
I would recommend the Pertronix ignition system, its a bolt on upgrade and replaces your points in your dizzy to an optical sensor. I got mine from ebay, landed here within 7days and all for about $80 nzd.LYDOS240z wrote:Hey, I need a left rear axle and does anyone know where I can get electronic conversion kits for my dizzy?
Are you still running a ballast resistor and standard coil? I would suggest getting a high output coil and taking the ballast resister out aswell so you can run a full 12+v all the time instead of just using 12v when you are cranking up the engine and dropping down to 8-9v when engine is running.
LYDOS240z
Re: 240z Parts
Im running a Bosch gt 40r 12volt with resistor??? lolZeeya wrote:I would recommend the Pertronix ignition system, its a bolt on upgrade and replaces your points in your dizzy to an optical sensor. I got mine from ebay, landed here within 7days and all for about $80 nzd.LYDOS240z wrote:Hey, I need a left rear axle and does anyone know where I can get electronic conversion kits for my dizzy?
