Hi guys just thought I would share my project with you.
Its a 75 gn620 which I am in the middle of upgrading to an sr20, so far I have the engine mounted and have got it running . The next stage is to get a radiator, a short shifter and get a drive shaft made up which will be happening as soon as I have saved up some money saved up.
Sent from my GT-P5110 using Tapatalk
Jayden's 620
Jayden's 620
Jayden's 620
New mounting points and old engine
Sent from my GT-P5110 using TapatalkYou do not have the required permissions to view the files attached to this post.
Re: Jayden's 620
nice one!
do you have a picture of the clearance of the drag link on the sump?
Jayden's 620
Brought a radiator this morning. It's a 52mm thick half size Honda radiator
I think I might have some clearance issues
Has anyone used these products before?
http://www.trademe.co.nz/motors/car-par ... 963810.htm" onclick="window.open(this.href);return false;
http://www.trademe.co.nz/motors/car-par ... 029667.htm" onclick="window.open(this.href);return false;
They look pretty ugly but they will do the trick as the radiator outlets are a different size to the engine
Sent from my Nexus 5 using TapatalkI think I might have some clearance issues
Jayden's 620
Tidied up the wiring in the engine bay a little bit and made a loom for the fuel pump and fuel sender unit. Also wired up the rev light's.
Re: Jayden's 620
I'm actually planning the exact same swap for my 620.
I have a motor from an s14.
Keep your updates coming.
Re: Jayden's 620
NA to begin with.
Then I'll likely fit an Eaton M62 supercharger. It looks like it should be pretty easy.
