I'd probably get the flanges on both sides cut, then Aluminium tubes welded between them. You never know how nicely the factory flange would weld. (I had a terrible time with an SC14 discharge manifold)
Just to let peeps know if you are making such a manifold its only possible on the 8 port head
The 4 port head has totally and incorrect location of ports in this area and I only found out
too late when I tried to place the weber flanges on.
There is a big bias on the 4 port head and makes it impossible to use the primary manifold.
regards, d
datso wrote:Just to let peeps know if you are making such a manifold its only possible on the 8 port head
regards, d
were you trying to mate the factory inlet flange to a weber flange?
if so could you get a new head flange cut and weld tubes between the flanges as bart describes
will use factory flange to make a new one but ports are 62mm x 44mm which are massive ports
and the oval shape will be hard to taper into custom tubing but have no other choice as 4 port
heads dont come around often and worthwhile to hold onto.
