as many are now aware iv upgraded (or downgraded?) to a ga16d-something. this will tear my standard h145 to pieces when the planned cams and induction kick in. even the a15 (kinda worked) blew a tooth or 2 off when just cruising the highway home through a 50km zone (woodend) WITHOUT ANY SKIDS/HIGH REVS OR THE LIKES.
i need drum to drum full setup including the plates that connect the rear shocks and u bolts together.
i realise those who have them are unlikely to let them go for nice money, but its an expense that i obviously have to pay.
i cant pinch the one in my ute either as it will be getting the a15 asap when coin allows. kinda saving it all for a h165..............
pm or txt/ring me on 0277270650
NEEDED: 1200 UTE DIFF H165 SETUP
1972 1200 coupe KB110
- woodies72coupe
Good luck Luke. I'll have a complete back end off a B310 wagon coming shortly, pretty sure it's the same!
Re: NEEDED: 1200 UTE DIFF H165 SETUP
Back end of a B310 Sunny wagon, odds on it would be a H150.
- Kitch
310 wagon would possibly be wider too? and are they leaf springs or coil like sedans?
(I dont know much about 310's - just guessing)
- Kitch
This may be an option Luke, gets you your diff, and spares for your ute.
and some parts to flick off.
http://www.trademe.co.nz/Browse/Listing ... =590837006" onclick="window.open(this.href);return false;
However the guy had this listed for "stupid" money originally (was it 4K or something?), then had it listed @ $1 reserve and pulled auction with one hour to go, as he was obviously concerned it was not going to go for much (bid was @ $200 at the time), currently top bid is @ $450 and no where near reserve. probably worth around 1500 ish?
what about cutting down a h190, 1200sss on here did one for his ca18det starlet, and it worked well, I know its not something you could do yourself, but there are enough people here to get it done , without costing more than a h165
- kartboy
- aka: Hayden
310 wagons are leaf spring.Kitch wrote:310 wagon would possibly be wider too? and are they leaf springs or coil like sedans?
if there are no ute diffs out there then il go h190?. does anyone know of one of these??
dirtyleppa
- aka: leppa
h190s come in the vannettes, 720 utes and later model live axle nissan serenas. problem is finding a good ratio diff. most of them are quite high ratios. if you can find one from a serena, you might find one with an LSD
but wont i need the housing and everything?dirtyleppa wrote:h190s come in the vannettes, 720 utes and later model live axle nissan serenas. problem is finding a good ratio diff. most of them are quite high ratios. if you can find one from a serena, you might find one with an LSD
