NEEDED: 1200 UTE DIFF H165 SETUP
luke
Datsun Addict
Post by luke »
as many are now aware iv upgraded (or downgraded?) to a ga16d-something. this will tear my standard h145 to pieces when the planned cams and induction kick in. even the a15 (kinda worked) blew a tooth or 2 off when just cruising the highway home through a 50km zone (woodend) WITHOUT ANY SKIDS/HIGH REVS OR THE LIKES.
i need drum to drum full setup including the plates that connect the rear shocks and u bolts together.
i realise those who have them are unlikely to let them go for nice money, but its an expense that i obviously have to pay.
i cant pinch the one in my ute either as it will be getting the a15 asap when coin allows. kinda saving it all for a h165..............
pm or txt/ring me on 0277270650
1972 1200 coupe KB110
woodies72coupe
Post by woodies72coupe »
Good luck Luke. I'll have a complete back end off a B310 wagon coming shortly, pretty sure it's the same!
Blair
Datsun Nutter
Re: NEEDED: 1200 UTE DIFF H165 SETUP
Post by Blair »
Back end of a B310 Sunny wagon, odds on it would be a H150.
Kitch
Post by Kitch »
310 wagon would possibly be wider too? and are they leaf springs or coil like sedans?
(I dont know much about 310's - just guessing)
Kitch
Post by Kitch »
This may be an option Luke, gets you your diff, and spares for your ute.
and some parts to flick off.
http://www.trademe.co.nz/Browse/Listing ... =590837006" onclick="window.open(this.href);return false;
However the guy had this listed for "stupid" money originally (was it 4K or something?), then had it listed @ $1 reserve and pulled auction with one hour to go, as he was obviously concerned it was not going to go for much (bid was @ $200 at the time), currently top bid is @ $450 and no where near reserve. probably worth around 1500 ish?
2 doors
Post by 2 doors »
what about cutting down a h190, 1200sss on here did one for his ca18det starlet, and it worked well, I know its not something you could do yourself, but there are enough people here to get it done , without costing more than a h165
kartboy
aka: Hayden
Post by kartboy »
Kitch wrote:310 wagon would possibly be wider too? and are they leaf springs or coil like sedans?
310 wagons are leaf spring.
luke
Datsun Addict
Post by luke »
if there are no ute diffs out there then il go h190?. does anyone know of one of these??
dirtyleppa
aka: leppa
Post by dirtyleppa »
h190s come in the vannettes, 720 utes and later model live axle nissan serenas. problem is finding a good ratio diff. most of them are quite high ratios. if you can find one from a serena, you might find one with an LSD
luke
Datsun Addict
Post by luke »
dirtyleppa wrote:h190s come in the vannettes, 720 utes and later model live axle nissan serenas. problem is finding a good ratio diff. most of them are quite high ratios. if you can find one from a serena, you might find one with an LSD
but wont i need the housing and everything?
